Hi, I have a CentOS server where I have many Golang web applications running, I use Caddy as a proxy server and all the sites are loading correctly. Now, I have a problem with a header, it seems like caddy is dropping the > Referer header and therefore I get some problems in my application.
Exactly, I am not able to call POST,PUT,DELETE ajax calls, only GET is executing correctly. I contacted one of the developers of a library that I am using, and he says that the proxy is dropping that header. I am sending these headers http://prntscr.com/f11zii
Should I enable that header in the caddyfile or something? in that case, how is it done?
Thanks!
