Caddy in Docker - unknown directive errors
I am trying to add a global response to my caddy server, and in adding a new block, I am getting the following error:-
{"level":"info","ts":1691501378.77935,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
Error: adapting config using caddyfile: /etc/caddy/Caddyfile:10: unrecognized directive: close
Using the caddy:2.7.2 image from docker hub:-
❯ docker compose exec caddy caddy version
v2.7.2 h1:QqThyoyUFAv1B7A2NMeaWlz7xmgKqU49PXBX08A+6xg=
I ran it within Docker (with Compose) using the following Dockerfile:-
FROM caddy:builder AS builder
RUN xcaddy build --with github.com/caddy-dns/cloudflare@a9d3ae2690a1d232bc9f8fc8b15bd4e0a6960eec
FROM caddy:2.7.2
Host is Debian 12 x86_64.
Running within docker, latest released version.
See the above Dockerfile.
FROM caddy:2.7.2
      - 80:80
      - ./caddyfiles/:/etc/my_caddy_files/
      - /home/penumbra/images/:/etc/images/:ro
      - /home/penumbra/audio/:/etc/audio/:ro
      - /home/penumbra/static/:/etc/static/:ro
      - caddy_data:/data
      - caddy_config:/config
    container_name: "caddy"
    env_file: .env
    build: .
      main:
  caddy_data:
  caddy_config:
  main:
    external: true
	email umbra@abstractumbra.dev
	acme_dns cloudflare {env.CF_TOKEN}
	# dns cloudflare {env.CF_TOKEN}
    # resolvers 1.1.1.1
import /etc/my_caddy_files/*.caddy
respond /robots.txt "User-Agent: *\nDisallow: /" 200 {
    close
abstractumbra.dev:443 {
	redir https://about.abstractumbra.dev/
:80, :443 {
	respond 404
Additional context:-
The response body also did not recognize the body directive within it either.
I assumed these were present in my version as they are outlined in the documentation
Ah, my mistake. It needed to be within a address/location block, like the :80, :443 at the end.
It’s called a “site block”. See Caddyfile Concepts — Caddy Documentation
