For development, a lot of platforms offer a webhook event but require HTTPS and a valid domain. A lot of people use ngrok, but I had an EC2 instance on hand and it allows me to get a non-randomized subdomain for the webhook.
I had the following working with nginx
subdomain -> ec2 instance running nginx as a process -> tunnel -> local machine
The change is to move from nginx
to caddy
in a docker instance using caddy-docker-proxy
subdomain -> docker/caddy-docker-proxy running on ec2 instance -> tunnel -> local machine
This is my caddy settings:
image: lucaslorentz/caddy-docker-proxy:ci-alpine
- 443:443
- CADDY_INGRESS_NETWORKS=caddy
- caddy
- caddy_data:/data
labels:
caddy_0: dev.domain.tld
caddy_0.reverse_proxy: 172.17.0.1:9000
I can confirm that caddy
gets the request from the subdomain based on the logs.
I can also confirm that if I curl localhost:9000/test
from the EC2 instance, it works.
This means that there is a disconnect between the docker container running caddy-docker-proxy
and the host machine/EC2 instance.
Here’s the error log from Caddy:
"level": "error",
"ts": 1695592513.784038,
"logger": "http.log.error",
"msg": "dial tcp :9000: connect: connection refused",
"request": {
"remote_ip": "redacted",
"remote_port": "60083",
"client_ip": "redacted",
"proto": "HTTP/2.0",
"method": "GET",
"host": ".com",
"uri": "/test",
"headers": {
"Sec-Fetch-User": [
"?1"
"Accept-Encoding": [
"gzip, deflate, br"
"Accept-Language": [
"en-US,en;q=0.9,de;q=0.8"
"Sec-Ch-Ua": [
"\"Chromium\";v=\"116\", \"Not)A;Brand\";v=\"24\", \"Google Chrome\";v=\"116\""
"Sec-Ch-Ua-Mobile": [
"?0"
"Sec-Ch-Ua-Platform": [
"\"macOS\""
"1"
"User-Agent": [
"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
"Accept": [
"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"
"Sec-Fetch-Site": [
"none"
"Sec-Fetch-Mode": [
"navigate"
"Cache-Control": [
"max-age=0"
"Sec-Fetch-Dest": [
"document"
"tls": {
"resumed": false,
"version": 772,
"cipher_suite": 4865,
"proto": "h2",
"server_name": "dev.domain.tld"
"duration": 0.00028104,
"status": 502,
"err_id": "ra595z5i9",
"err_trace": "reverseproxy.statusError (reverseproxy.go:1248)"
I run my tunnel from my Macbook with this:
tunneldev() {
emulate -LR bash;
echo "Tunneling $1 on core server to $2 on localhost";
ssh -R $1:localhost:$2 -N lab;
tunneldev 9000 3000
Feels like I just need one more setting to allow the docker container to properly send traffic through the tunnel but can’t find it.
