Running on RaspberryPi 4 4GB using portainer with docker compose on top of OpenMediaVault5. I am running adguard and dnsmasq to resolve my subdomains.
version: "2"
image: caddy
hostname: caddy
- MY_DOMAIN
- /srv/dev-disk-by-label-data/data/appdata/Config/Caddy/Caddyfile:/etc/caddy/Caddyfile:ro
- /srv/dev-disk-by-label-data/data/appdata/Config/Caddy/data:/data
- /srv/dev-disk-by-label-data/data/appdata/Config/Caddy/config:/config
default:
external:
MY_DOMAIN = lxiscs.duckdns.org
Caddyfile
lxiscs.duckdns.org
tiddlywiki.{$MY_DOMAIN} {
reverse_proxy 192.168.0.29:8081
grocy.{$MY_DOMAIN} {
reverse_proxy https://192.168.0.29:32771 {
tls_insecure_skip_verify
I am just getting into self hosting applications and needed a way to use HTTPS with grocy(in order to access from Android app) and since I would like to be able to access services(home assistant, grocy, eventually from outside my network I started with Caddy. My current setup seems to be working ok, I am mostly concerned if I am opening up any security risks with the tls_insecure_skip_verify between Caddy and the end applications when they are both running inside my network? Is there anything else I should keep in mind as I add more servers/services?
