I have installed Caddy using docker-compose.yml as a reverse proxy.
docker-compose.yml:
version: '3.8'
container_name: "caddy"
image: caddy:latest
- 443:443
- "127.0.0.1:2019:2019"
- /var/docker/caddy/data:/data
- /var/docker/caddy/config:/config
- /var/docker/caddy/Caddyfile:/etc/caddy/Caddyfile
- /var/docker/caddy/logs:/var/log/caddy
labels:
- "prometheus.io/scrape=true"
- "prometheus.io/port=2019"
- "prometheus.io/metrics_path=/metrics"
Caddyfile:
email ssl@email.com
admin :2019
metrics
format json
level INFO
domain.com {
reverse_proxy docker-container:3000
log
@metrics_public {
path /metrics
not remote_ip private_ranges
respond @metrics_public 403
I want to see only the metrics related to docker-container:3000 in Grafana.
I tried using the following query:
caddy_http_requests_total{host="domain.com"}
but it is not working.
I also tried adding a label to the metrics, but that didn’t work either.
What should I add to make it work correctly? I couldn’t find anything relevant in the documentation.
