Hello!
My caddy installation worked fine for some time. Last night a had an issue with a backup-job, which filled the disk which also holds caddy 100%. Immediately in the morning I fixed the situation and restarted the server. Caddy now fails to start.
Error: loading initial config: loading new config: http app module: start: finalizing automatic HTTPS: managing certificates for [share.fp.on.at web.fp.on.at]: automate: manage [share.fp.on.at web.fp.on.at]: share.fp.on.at: caching certificate: decoding certificate metadata: unexpected end of JSON input
Error: caddy process exited with error: exit status 1
root@webserver:/var/log/caddy # caddy version
v2.8.4
via the FreeBSD package manager “pkg”.
FreeBSD fractal.fp.on.at 13.1-RELEASE-p9 FreeBSD 13.1-RELEASE-p9 n245431-b8ec9bde091 TRUENAS amd64
Caddy runs in a container (iocage).
service caddy start
d. What I already tried:
The logmessage quite obviously points to a corrupted certificate cache file. I’m only struggling to find where to find that.
I found the directory
root@webserver:/var/log/caddy # ls -lsha /var/db/caddy/data/caddy/
total 16
9 drwx------ 6 root wheel 8B Sep 23 15:55 .
1 drwx------ 3 root wheel 3B Jul 25 16:51 ..
1 drwx------ 3 root wheel 3B Jul 25 16:51 acme
1 drwx------ 3 root wheel 3B Jul 25 16:51 certificates
1 -rw------- 1 root wheel 36B Jul 25 16:51 instance.uuid
5 -rw------- 1 root wheel 112B Oct 11 11:24 last_clean.json
1 drwx------ 2 root wheel 2B Oct 12 10:38 locks
1 drwx------ 2 root wheel 4B Oct 9 11:24 ocsp
Should I just delete the contents of “certificates”?
Any advice welcome. Thanks!
