Hi, I’m trying to reverse proxy using Caddy, I’ve set up my domain in the Caddyfile but when checking the logs I cannot see anything related to my request, as if Caddy doesn’t even receive it. I’ve tried requesting from both my browser and curl, absolutely no mention of them in the logs. I’m using Cloudflare, proxied mode, an A record is pointed to my server’s IP address.
Jul 29 16:40:50 v20709 systemd[1]: Starting Caddy...
Jul 29 16:40:51 v20709 caddy[1752]: caddy.HomeDir=/var/lib/caddy
Jul 29 16:40:51 v20709 caddy[1752]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Jul 29 16:40:51 v20709 caddy[1752]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Jul 29 16:40:51 v20709 caddy[1752]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Jul 29 16:40:51 v20709 caddy[1752]: caddy.Version=v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=
Jul 29 16:40:51 v20709 caddy[1752]: runtime.GOOS=linux
Jul 29 16:40:51 v20709 caddy[1752]: runtime.GOARCH=amd64
Jul 29 16:40:51 v20709 caddy[1752]: runtime.Compiler=gc
Jul 29 16:40:51 v20709 caddy[1752]: runtime.NumCPU=4
Jul 29 16:40:51 v20709 caddy[1752]: runtime.GOMAXPROCS=4
Jul 29 16:40:51 v20709 caddy[1752]: runtime.Version=go1.22.3
Jul 29 16:40:51 v20709 caddy[1752]: os.Getwd=/
Jul 29 16:40:51 v20709 caddy[1752]: LANG=C.UTF-8
Jul 29 16:40:51 v20709 caddy[1752]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Jul 29 16:40:51 v20709 caddy[1752]: NOTIFY_SOCKET=/run/systemd/notify
Jul 29 16:40:51 v20709 caddy[1752]: HOME=/var/lib/caddy
Jul 29 16:40:51 v20709 caddy[1752]: LOGNAME=caddy
Jul 29 16:40:51 v20709 caddy[1752]: USER=caddy
Jul 29 16:40:51 v20709 caddy[1752]: INVOCATION_ID=5caf4f6f565843288238397e8b8bfac9
Jul 29 16:40:51 v20709 caddy[1752]: JOURNAL_STREAM=8:17222
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0793095,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0816002,"msg":"adapted config to JSON","adapter":"caddyfile"}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.083217,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0835612,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0836062,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"debug","ts":1722271251.0836575,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:6969"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:3000"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0837429,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00077c380"}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0845997,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"debug","ts":1722271251.0849192,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0849485,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"debug","ts":1722271251.0850174,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0850337,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0850434,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["m1.masscoin.xyz","masscoin.xyz"]}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"debug","ts":1722271251.0860136,"logger":"tls.cache","msg":"added certificate to cache","subjects":["m1.masscoin.xyz"],"expiration":1729965351,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"c5e790b8dc0bdd134e49cde17d8f60b630012c9bce1226cfec79838c3b67cda0","cache_size":1,"cache_capacity":10000}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"debug","ts":1722271251.0860877,"logger":"events","msg":"event","name":"cached_managed_cert","id":"65acec04-751b-4bf7-80ea-1e801709774c","origin":"tls","data":{"sans":["m1.masscoin.xyz"]}}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"debug","ts":1722271251.0868843,"logger":"tls.cache","msg":"added certificate to cache","subjects":["masscoin.xyz"],"expiration":1729963166,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"d3dde5368763bd78f31cc9f3dfb410793fce20a3212fa284d0b4cfa87c442c12","cache_size":2,"cache_capacity":10000}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"debug","ts":1722271251.0869498,"logger":"events","msg":"event","name":"cached_managed_cert","id":"b316856f-c822-4107-acfb-25d3e13450d7","origin":"tls","data":{"sans":["masscoin.xyz"]}}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.087501,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0876515,"msg":"serving initial configuration"}
Jul 29 16:40:51 v20709 systemd[1]: Started Caddy.
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.095408,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"a14c16f4-9336-4a71-88d1-1448c5ea73d1","try_again":1722357651.095402,"try_again_in":86399.999998806}
Jul 29 16:40:51 v20709 caddy[1752]: {"level":"info","ts":1722271251.0955782,"logger":"tls","msg":"finished cleaning storage units"}
sudo apt update
sudo apt install caddy
sudo systemctl daemon-reload
sudo systemctl enable --now caddy
Debian GNU/Linux 11 (bullseye)
Linux 5.10.0-31-cloud-amd64
x86/64
systemd 247 (247.3-7+deb11u5)
+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified
# to start Caddy
# to send requests to the server (on windows)
curl -vL masscoin.xyz
masscoin.xyz {
reverse_proxy localhost:3000
m1.masscoin.xyz {
reverse_proxy {
to http://localhost:6969
