I’m having an issue: a Caddy reverse proxy offering H2+ can’t be browsed through Wireguard tunnel.
However, I have another IPSec VPN that points to the same Caddy and that works just fine.
My idea was to force the downgrade of H2+ to H1 using Request matchers, however I seem not to find the good settings.
The relevant sections of my Caddy file are the following:
http_port 80
https_port 443
admin off
email "MyEmail@example.com"
servers :443 {
listener_wrappers {
http_redirect
tls
servers :80 {
protocols h1 h2c
(ip-whitelist) {
@privatefilter {
not remote_ip 192.168.1.0/24 10.0.0.0/24
abort @privatefilter
(common-proxy) {
header_down -Server
header_down -X-Powered-By
*.example.com {
@subdomain1 host subdomain1.example.com
handle @subdomain1 {
import ip-whitelist
reverse_proxy MyRealWebServer:Port {
import common-proxy
@subdomain2 host subdomain2.example.com
handle @subdomain2 {
..... etc. ......
As I said, my initial idea was to add some sort of conditional TLS section but the issue is that I cannot recall remote_ip from inside of a reverse_proxy section, or I’m doing something else wrong.
My Wireguard IP range is 10.0.0.0/24, I was thinking to use that as remote_ip and in that case add the relevant section to the reverse_proxy.
Top section added:
(h2check) {
@h2filter {
remote_ip 10.0.0.0/24
transport @h2filter http {
versions 1.1
Modified section:
import ip-whitelist
import h2check
import common-proxy
Is there a way to check a request variable and influence the transport section?
2023/07/01 15:14:08.729 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": "caddyfile"}
Error: adapting config using caddyfile: parsing caddyfile tokens for 'handle': /etc/caddy/Caddyfile:133 - Error during parsing: parsing caddyfile tokens for 'reverse_proxy': /etc/caddy/Caddyfile:31 - Error during parsing: unrecognized response matcher remote_ip
/srv $ caddy version
Docker image:
caddy:latest@sha256:050db1833a9c3bee6699e344442199769ebfd076525de385a1eb47318b900119
Docker + Portainer
