Caching middleware for caddy:
caddy-cache
我使用windows,不会编辑Go语言.生成Caddy,这是个遗憾.
我喜欢Caddy,感谢nicolasazrak
caddy-cache
I hope the official can add “caddy-cache”
This looks great! (I haven’t tried it, but the benchmarks look appealing.)
This wiki page will tell you how to submit your plugin for the Caddy website: https://github.com/mholt/caddy/wiki/Publishing-a-Plugin-to-the-Download-Page
Just remember to submit the directive via PR to the Caddy repo first. Instructions here: https://github.com/mholt/caddy/wiki/Writing-a-Plugin:-Directives#3-order-your-directive
You should also read over this (new, incomplete) page about HTTP middlewares; there might be something here you didn’t know before: https://github.com/mholt/caddy/wiki/Things-HTTP-Middleware-Developers-Should-Know
Hello, Matt.
你好,@matt
I’m sorry, I can’t submit a plug-in because I’m not the author.
我很遗憾,因为我不是作者,所以不能提交插件.
I can’t compile and use him in the Windows 64 system,Because I don’t “Go” language.
我不能在Windows 64系统中编译和使用他,因为我不使用“go”语言。
I’m sorry to say that.
我很抱歉这样说。
Okay. The author of the plugin will need to submit it. You should +1 the issue about it on that repo!
I can’t contact the author visually.Because of language problems.
