Hi,
i am trying to have Caddy and single instance of Oauth2-proxy to provide authentication for multiple upstreams.
what happens is that after successful EntraID authentication, i get again 401 and back to the Azure authentication page.
Using docker. here is docker compose file
image: ghcr.io/caddybuilds/caddy-cloudflare:latest
- ${VOLUME_DIR:-./.volumes}/caddy/data:/data
- ${VOLUME_DIR:-./.volumes}/caddy/config:/config
- ${VOLUME_DIR:-./.volumes}/caddy/Caddyfile:/etc/caddy/Caddyfile
- /root/.public/:/srv/public:ro
# http
# https
- "proxy"
oauth2-proxy:
image: quay.io/oauth2-proxy/oauth2-proxy:v7.12.0
container_name: oauth2-proxy
OAUTH2_PROXY_HTTP_ADDRESS: "0.0.0.0:4180"
OAUTH2_PROXY_REVERSE_PROXY: true
OAUTH2_PROXY_EMAIL_DOMAINS: "*"
OAUTH2_PROXY_COOKIE_NAME: "_oauth2_proxy"
OAUTH2_PROXY_COOKIE_SECRET: "secret"
OAUTH2_PROXY_COOKIE_DOMAIN: ".proxy.domain.dev"
OAUTH2_PROXY_COOKIE_SECURE: "true"
OAUTH2_PROXY_COOKIE_SAMESITE: lax
OAUTH2_PROXY_WHITELIST_DOMAINS: ".proxy.domain.dev"
OAUTH2_PROXY_SET_XAUTHREQUEST: "true"
OAUTH2_PROXY_PROVIDER: oidc
OAUTH2_PROXY_CLIENT_ID: "client-id"
OAUTH2_PROXY_CLIENT_SECRET: "client-secret"
OAUTH2_PROXY_OIDC_ISSUER_URL: "https://login.microsoftonline.com/<tenant-id>/v2.0"
OAUTH2_PROXY_REDIRECT_URL: "https://auth.proxy.domain.dev/oauth2/callback"
OAUTH2_PROXY_SCOPE: "openid email profile offline_access"
OAUTH2_PROXY_UPSTREAMS: "file:///dev/null"
- "4180:4180"
- "proxy"
proxy:
acme_dns cloudflare ""
https://auth.proxy.domain.dev {
reverse_proxy oauth2-proxy:4180
*.proxy.domain.dev {
handle /oauth2/* {
reverse_proxy oauth2-proxy:4180 {
header_up X-Forwarded-Uri {uri}
forward_auth oauth2-proxy:4180 {
uri /oauth2/auth
@unauth status 401 403
handle_response @unauth {
redir https://auth.proxy.domain.dev/oauth2/start?rd={scheme}://{host}{uri}
@sub1 host sub1.proxy.domain.dev
handle @sub1 {
reverse_proxy https://upstream1.fqdn:123 {
keepalive_idle_conns 8
max_conns_per_host 16
tls_insecure_skip_verify
@sub2 host sub2.proxy.domain.dev
handle @sub2 {
reverse_proxy https://upstream2.fqdn:123 {
