v2.4.3
Caddy is being used as a reverse-proxy. Apache is listening on port 88.
CentOS 7, systemd
Paste command here.
cloud.site.com:443 {
output file /var/log/caddy-access.log
format json
tls /root/.acme.sh/cloud.site.com/fullchain.cer /root/.acme.sh/cloud.site.com/cloud.servutech.com.key
reverse_proxy /v2ray localhost:9999
#reverse_proxy https://www.bing.com {
reverse_proxy 127.0.0.1:88 {
header_up X-Real-IP {http.request.remote}
header_up X-Forwarded-For {http.request.remote}
header_up X-Forwarded-Proto {http.request.scheme}
If a user types an address, without a trailing slash, into their browser’s address bar, the hand-off from Caddy to Apache fails. For example: a user types: https://cloud.site.com/folder
(without trailing slash). They are redirected to: http://127.0.0.1:88/folder/
and get an unable to connect browser error. Whereas if the user enters https://cloud.site.com/folder/
(with trailing slash) they are taken to that URL.
How do I fix this?
