Caddy 2 in VM. Cloudflare SSL handshake error 525
1. Caddy version (caddy version): 2.4.3
Ubuntu-20.04.2 Server. Running as a VM on Proxmox VE. Proxmox installed on Intel NUC
systemctl start caddy
N/A
# domain name.
#:80 {
#	root * /usr/share/caddy
#	file_server
	# php_fastcgi localhost:9000
portainer.mydomain.com.au {
	reverse_proxy 192.168.1.156:9000
hass.mydomain.com.au {
	reverse_proxy 192.168.1.156:8123
I have been building a homelab with the intention of running home assistant behind a reverse proxy.
I had Caddy 2 installed and working with the above caddyfile when I had Linux Mint installed on the bare metal.
I have since decided that I want to use home assistant OS instead of the docker container. For ease of versioning I decided to go with a proxmox VM.
I currently have 2 VMs. A Home assistant OS instance that is set up and working correctly, and a second Ubuntu server VM.
I set up caddy 2 on the ubuntu VM in the exact same manner as I did originally with the linux mint install. With the same caddy file. However, when I access hass.mydomain.com.au or portainer.mydomain.com.au I am getting a cloudflare SSL handshake failed 525 error.
It is perplexing as when I swap out the SSD in the NUC back to the one that has the linux mint install, everything works perfectly.
I am at a loss as to what to do next to get caddy working in the VM.
