Amazon Linux 2
service caddy start
After=network.target
ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/config.json
ExecReload=/usr/bin/caddy reload --config /etc/caddy/config.json
"admin": {
"disabled": false,
"listen": "0.0.0.0:2020",
"config": {
"persist": true
"logging": {
"sink": {
"writer": {
"output": "file",
"filename": "/tmp/caddy-Go.log"
"logs": {
"default": {
"writer": {
"output": "file",
"filename": "/tmp/caddy-tmp.log"
"encoder": {
"format": "json"
"level": "WARN"
"apps": {
"tls": {
"automation": {
"policies": [{
"subjects": ["*.domain.com"],
"issuer": {
"module": "acme",
"email": "soporte@domain.com",
"challenges": {
"dns": {
"provider": {
"name": "cloudflare",
"api_token": "MY_API_TOKEN"
"on_demand": false
"issuer": {
"module": "acme",
"on_demand": true
"on_demand": {
"rate_limit": {
"interval": "5m",
"burst": 100
"ask": "http://certs.domain.com/delegated.php"
"http": {
"http_port": 80,
"https_port": 443,
"servers": {
"tiendas": {
"@id": "domaincerts",
"listen": [":80",":443"],
"max_header_bytes": 41943040,
"routes": [
"group": "grupo2",
"match": [{
"host": [
"dev-pos.domain.com"]
"handle": [{
"handler": "encode",
"encodings": {
"gzip": {},
"zstd": {}
"handler": "reverse_proxy",
"upstreams": [{
"dial": "172.31.7.34:80"
"terminal": true
"group": "grupo2",
"match": [{
"host": [
"dev-apipos.domain.com",
"dev-admintienda.domain.com",
"dev-tienda.domain.com"]
"handle": [{
"encodings": {
"gzip": {},
"zstd": {}
"upstreams": [{
"dial": "172.31.4.60:80"
"terminal": true
"group": "grupo1",
"match": [{
"host": ["certs.domain.com"]
"handle": [{
"transport": {
"protocol": "fastcgi",
"root": "/var/www/html/"
"upstreams": [{
"dial": "unix//var/php.sock"
"terminal": true
"group": "grupo1",
"match": [{
"host": ["admintienda.domain.com"]
"handle": [{
"encodings": {
"gzip": {},
"zstd": {}
"upstreams": [{
"dial": "172.31.60.234:80"
"group": "grupo1",
"match": [{
"host": ["apipos.domain.com"]
"handle": [{
"encodings": {
"gzip": {},
"zstd": {}
"upstreams": [{
"dial": "172.31.63.108:80"
"group": "grupo1",
"match": [{
"host": ["api.domain.com"]
"handle": [{
"encodings": {
"gzip": {},
"zstd": {}
"upstreams": [{
"dial": "172.31.8.83:80"
"group": "grupo1",
"match": [{
"host": ["*.domain.com"]
"handle": [{
"encodings": {
"gzip": {},
"zstd": {}
"upstreams": [{
"dial": "172.31.53.124:80"
"terminal": true
"group": "grupo1",
"handle": [{
"encodings": {
"gzip": {},
"zstd": {}
"upstreams": [{
"terminal": true
Caddy crashed. This is the seconfd time. The first one I didnt know where to find the logs.
Aug 20 00:00:54 ip-172-31-0-158 caddy: panic: runtime error: invalid memory address or nil pointer dereference
Aug 20 00:00:54 ip-172-31-0-158 caddy: [signal SIGSEGV: segmentation violation code=0x1 addr=0x2d8 pc=0x8c4d71]
Aug 20 00:00:54 ip-172-31-0-158 caddy: goroutine 67822778 [running]:
Aug 20 00:00:54 ip-172-31-0-158 caddy: github.com/caddyserver/certmagic.(*Cache).updateOCSPStaples(0xc006547e50, 0x1942ec0, 0xc0049433c0)
Aug 20 00:00:54 ip-172-31-0-158 caddy: github.com/caddyserver/certmagic@v0.10.12/maintain.go:238 +0x271
Aug 20 00:00:54 ip-172-31-0-158 caddy: github.com/caddyserver/certmagic.(*Cache).maintainAssets(0xc006547e50)
Aug 20 00:00:54 ip-172-31-0-158 caddy: github.com/caddyserver/certmagic@v0.10.12/maintain.go:52 +0x20b
Aug 20 00:00:54 ip-172-31-0-158 caddy: created by github.com/caddyserver/certmagic.NewCache
Aug 20 00:00:54 ip-172-31-0-158 caddy: github.com/caddyserver/certmagic@v0.10.12/cache.go:113 +0x145
Aug 20 00:00:54 ip-172-31-0-158 systemd: caddy.service: main process exited, code=exited, status=2/INVALIDARGUMENT
Aug 20 00:00:54 ip-172-31-0-158 systemd: Unit caddy.service entered failed state.
I dont know what to do
