I’m not sure I understand what this will achieve. The UUID is not derived from, nor can it reveal, any identifying information about the server it came from - except for the fact that it’s tied to the data it came with.
Hashing it doesn’t stop someone from requesting all data for a given UUID, it doesn’t protect any sensitive secrets or credentials from the database owner (as the UUID is neither), and it doesn’t stop the database owner from separating out any discrete instance of Caddy.
I suppose you could argue that the database owner can’t take the hash and put straight in to the front-end of the metrics site, but why would they do that when they can just look at the data in the database?
UUIDs are equally meritorious as hashed UUIDs or any other sufficiently random token for authentication purposes.
I’d argue that the data isn’t actually related to the site at all, but to Caddy itself. These aren’t web logs - they’re aggregated Caddy response latencies, MITM counts, TLS implementation, etc. across the entire web server. Once they’re aggregated locally, they’re indistinguishable.
So if someone higher up dictates that these stats can’t be included in the aggregate, I’d say that the entire server should be telemetry-disabled. There’s no real difference between the stats from a safe site and the stats from a sensitive site, so it would be best for it all to go off.
I don’t want to speak for Matt, but when I refer to the server admin, I mean the person ultimately responsible for the server, with the power to make decisions about what software runs on it. In this case, the person who provisions the server and puts the Caddy binary on it is the server admin, and they have the ability to choose whether they want telemetry. If I were just logging on to administer the web server, I’d be the web admin.
In the end, everyone either uses pre-compiled binaries or compiles it themselves.
