2.2.1
bin/caddy run -config assets/conf/Caddyfile
macOS Catalina
paste full file contents here
@blocklist {
import blockeduseragents.conf
import blockedreferers.conf
import blockedproxytargets.conf
rewrite @blocklist /bad-actor
respond /bad-actor 403
# List all bad User-Agents:
header User-Agent STRING1*
header User-Agent STRING2*
# List all bad Referrers:
header Referer *STRING3
header Referer *STRING4
I want to build lists of known bad actor attributes and if a request matches ANY of the many configured tests I’ll rewrite and 403 as above.
I can build and format the conf file content from lists available externally.
But as a newbie I’m confused. As I understand it, all these tests will be AND’d and not OR’d… unless each test is defined in its own match set.
Am I right? Each conf file could contain a few hundred tests…
Is the V2 matcher design intended for this sort of use or should I go ahead and write a custom matcher to work on bulk configuration like this?
Maybe as a newbie I just missed the right feature to use
