2.4.3
I run Caddy as a systemd service on a Raspberry Pi.
Raspberry Pi OS (Raspberry Pi reference 2021-05-07)
systemd 241
sudo systemctl start caddy
From /lib/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
Caddyfile
import /etc/caddy/*.caddyfile
/etc/caddy/nextcloud.caddyfile
myddnssubdomain.ddns.net {
root * /var/www/nextcloud
output file /media/cloud/logs/caddy/nextcloud.log
level DEBUG
php_fastcgi unix//run/php/php7.3-fpm.sock
# enable HSTS
tls internal {
on_demand
@forbidden {
path /.htaccess
path /data/*
path /config/*
path /db_structure
path /.xml
path /README
path /3rdparty/*
path /lib/*
path /templates/*
path /occ
path /console.php
respond @forbidden 404
I am trying to expose a Caddy-hosted Nextcloud instance in my local network to the Internet. I use the Dynamic DNS service from no-ip.com. I can actually reach the Nextcloud instance but browsers are throwing errors that the certificate can not be trusted.
The problem does not appear when hosting at raspberrypi.local
in my LAN.
SEC_ERROR_UNKNOWN_ISSUER
on Firefox
NET::ERR_CERT_AUTHORITY_INVALID
on Chrome
I tried to find out if there are any additional steps needed to get Caddy to work with Dynamic DNS. It seems, later down the road I need the caddy-dynamicdns
plugin to react to IP changes but this seems unrelated to my current problem.
