Blank page for my endpoint with SSL
Hello,
I’m trying to set up a server behind Caddy using Docker, with Cloudflare DNS for TLS. Locally everything works fine (with a local mediaserver name using tls internal), but when I access the remote domain (https://server.mydomain.com:32500) I get a blank page — the response has HTTP 200 status, it says the cert is OK but the content length is 0 and no body is returned. Port is open and forwarded via my router, I can see it hitting caddy:
Log:
caddy     | {"level":"debug","ts":1753694259.6074917,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"*.mydomain.com","subjects":["*.mydomain.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"X"}
caddy     | {"level":"debug","ts":1753694259.6075118,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"192.168.5.1","remote_port":"51394","subjects":["*.mydomain.com"],"managed":true,"expiration":1761465176,"hash":"X"}
Blank page
docker-compose.yaml:
version: '3'
    image: ghcr.io/caddybuilds/caddy-cloudflare:latest
      - "8096:8096" # local
      - "32500:443" # external
      - caddy_data:/data
      - caddy_config:/config
      - CADDY_DEBUG=true
      - CLOUDFLARE_API_TOKEN=${CLOUDFLARE_API_TOKEN}
      - web
  web:
  caddy_data:
  caddy_config:
ubuntu
docker compose up
    email myemail@gmail.com
https://mediaserver:8096 {
    respond "Hello server" 200
    tls internal
server.mydomain.com:443 {
Thank you for your help!
You’ve obfuscated the domain, the ports don’t match, and the logs are incomplete. There’s no way we can identify misconfiguration issues. Please share properly full details.
What do you mean port don’t match? I map 32500 to 443 and listen to 443 in my caddyfile.
I will share full details when I’m back later. Thanks for your help!
Please share the following as well:
curl -kv https://server.mydomain.com:32500
And Caddy’s debug log.
