Blank display after installation
1. Caddy version (2.2.1):
Digital Ocean marketplace
1 GB Memory / 25 GB Disk / AMS3 - on Ubuntu 18.04
sudo systemctl reload caddy
Rather folder- and filenames
$ cd /var/www/
$ alternativephotography.eu  issue.log
alternativephotography.eu, www.alternativephotography.eu {
    root *  /var/www/alternativephotography.eu
        output file /var/www/issue.log
I’m unable to see my website. No matter what I tried, the page stays blank. Even a simple index.html file with nothing more than Hello World will not load. The browser reports a 200 but the logs show a 404.
{“level”:“error”,“ts”:1639737232.8647988,“logger”:“http.log.access.log0”,“msg”:“handled request”,“request”:{“remote_addr”:“178.119.9.45:44150”,“proto”:“HTTP/2.0”,“method”:“GET”,“host”:“alternativephotography.eu”,“uri”:"/",“headers”:{“User-Agent”:[“Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.1 Safari/605.1.15”],“Accept”:[“text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8”],“Accept-Language”:[“en-gb”],“Accept-Encoding”:[“gzip, deflate, br”]},“tls”:{“resumed”:false,“version”:772,“cipher_suite”:4865,“proto”:“h2”,“proto_mutual”:true,“server_name”:“alternativephotography.eu”}},“common_log”:“178.119.9.45 - - [17/Dec/2021:10:33:52 +0000] “GET / HTTP/2.0” 404 0”,“duration”:0.000146963,“size”:0,“status”:404,“resp_headers”:{“Server”:[“Caddy”]}}
I tried changing the location of my files;
used root index.html instead of root *;
used file_server browse;
respond shows the correct text;
tried setting up as a single domain (without the { });
chmod permissions to -R 644 of the folder.
https://alternativephotography.eu
The browser shows 404 for me. Must be something about your cache, DNS, or something else about your system/network.
404 for a request to a directory is usually because the folder doesn’t exist, or it doesn’t contain an index file. So check on those things.
That’s a pretty old version of Caddy. Please upgrade! The latest is v2.4.6.
The DO image should be configured to update Caddy by running sudo apt update && sudo apt upgrade.
Make sure the caddy user has permission to read that directory. The systemd service runs Caddy using that user.
The issue was indeed with the permissions. Once set to 777 I found no issues. I changed the owner of the files and reversed it to 555 solving all issues!
