I’m trying to understand what is the best practices to handle errors in a chain of modules that run inside route block.
If I want that once I get an error in my custom module, the chain will stop and not continue to the next module, should I return nil? or maybe the error itself and then use handle_errors block: handle_errors (Caddyfile directive) — Caddy Documentation?
What happen if I return nil but still write the bytes to the ResponseWriter?
Does caddy recognize it as no error? (from what I checked, that’s what happen).
This is an example for how I stop the chain for now:
func (m Middleware) ServeHTTP(w http.ResponseWriter, r *http.Request, next caddyhttp.Handler) error {
err := ..
if err != nil {
w.WriteHeader(http.StatusInternalServerError)
return nil
} else {
next.ServeHTTP(w, r)
Is this how Caddy expect to stop the chain and handler errors?
Thanks!
No error message, because it's a best practices question
v2.8.4
golang:1.23-alpine docker image inside kubernetes
caddy run --config /etc/caddy/Caddyfile
:2022 {
route /* {
custom_module_a
custom_module_b
