Hi. Following official docs at basicauth (Caddyfile directive) β Caddy Documentation, I tried to setup basic auth but run into the issue, that the directive seems to be different and results this way in an error.
v2.1.1
via docker-compose
image: caddy:2.1.1-alpine
- 443:443
Docker, alpine
basicauth /secret/* {
Bob JDJhJDEwJEVCNmdaNEg2Ti5iejRMYkF3MFZhZ3VtV3E1SzBWZEZ5Q3VWc0tzOEJwZE9TaFlZdEVkZDhX
my.test-domain.io {
root * /usr/share/my-app
3. The problem Iβm having:
Starting caddy results in the following error:
caddy_1 | {"level":"info","ts":1632204348.0622334,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1 | run: adapting config using caddyfile: /etc/caddy/Caddyfile:6: unrecognized directive: Bob
Error: unrecognized directive: Bob
other passwords
