Basic Auth not working?
I am running Shell In A Box using a reverse proxy. To make this a little more secure I would like to add basic authentication. The section of my Caddyfile for this looks like so:
domainname.org {
        basicauth /* {
                User $2a$14$qtL.ZzIBdvKaiP4UsbOXOOJl6EiNzNqZw09LXBtkowEa.WKB2Svfm
        reverse_proxy localhost:6175
However, this does not appear to do anything and the Shell In A Box page loads with no authentication pop-up
*   Trying external.ip.address:443...
* Connected to domainname.org (external.ip.address) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CApath: /etc/ssl/certs
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
* SSL connection using TLSv1.3 / TLS_CHACHA20_POLY1305_SHA256
*  subject: CN=domainname.org
*  start date: Dec  4 18:34:01 2023 GMT
*  expire date: Mar  3 18:34:00 2024 GMT
*  subjectAltName: host "domainname.org" matched cert's "domainname.org"
* Using Stream ID: 1 (easy handle 0xaaaac914e970)
> GET / HTTP/2
> Host: domainname.org
> user-agent: curl/7.81.0
> accept: */*
< HTTP/2 200
< content-type: text/html
< server: Caddy
< date: Fri, 02 Feb 2024 10:04:43 GMT
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE html PUBLIC.......etc.
Installed via apt repository
Ubuntu 22.04, systemd
Did you reload Caddy after changing your config?
Yes, with caddy adapt in the folder with the Caddyfile
Oh my goodness. I just realised that I needed to do a caddy reload as well.
Working now. Thank you!
All adapt does is show you the JSON version of your config. It doesn’t reload.
