1. My Caddy version (caddy version
v2 RC3
Dockerized, standard
Ubuntu 19 LTS
Is there a simple way to restrict basic_auth to only remote networks and not a local network? I see the way to define networks but cannot figure out how to limit basic_auth to certain networks.
Cheers!
Yep! You can use the not
matcher with the remote_ip
matcher in a named matcher block! It would look something along these lines:
@notLocal {
not remote_ip 192.168.0.1/24
basicauth @notLocal {
You’re right @axp , thanks for the correction - just copied that from the top post assuming it was correct.
system
(system)
closed
June 4, 2020, 12:30pm
#6
