v2.4.5
Caddy on a Digital Ocean instance.
Linux caddy 4.15.0-156-generic #163-Ubuntu SMP Thu Aug 19 23:31:58 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
sudo systemctl start caddy
Type=notify
# domain name.
on_demand_tls {
ask http://localhost:5555
interval 2m
burst 5
https:// {
on_demand
reverse_proxy https://example.com {
I want to have a way to dynamically reverse proxy to a domain with a variable component. E.g.
https:// {
on_demand
reverse_proxy https://example.com/*username*
Where username is the variable component. Without needing to update the Caddyfile and restart the service for each user that points their domain to our app.
We want to allow users of our app to add custom domains to their publicly available app url. Currently they are only pointed to the main application. I am really not sure if this is even possible without explicitly updating the Caddyfile for each user. My initial thoughts are:
The
ask
server’s response can include data which is accessible in a variable in the Caddyfile, since this server needs to read db info anyway it can include some metadata that will allow to be appended to the reverse_proxy uri and make it dynamic. -
We don’t want to require the users to have a specific URI structure when they point their domain to us.
Null
I only set up the basic reverse proxy to the main app uri with automatic https, and deployed a small Nodejs server to handle the ask
operation on an internal port. This functionality works as expected.
