caddy:2.4.2-alpine
{$SERVICE_DOMAIN} {
reverse_proxy service:3000
{$APP_DOMAIN} {
root * /var/www/html/app
encode gzip zstd
try_files {path} {path}/ /index.html
Docker image 2.4.2-alpine
docker compose up
version: '3.7'
app:
container_name: app
image: ${APP_IMAGE}
- static-content:/home/node/app/dist/app
service:
container_name: service
image: ${SERVICE_IMAGE}
- DB_HOST=database
- NODE_ENV=${NODE_ENV}
- DB_PASSWORD=${DB_PASSWORD}
- JWT_SECRET=${JWT_SECRET}
- backend
depends_on:
- database
database:
container_name: database
image: postgres:13.1-alpine
- POSTGRES_PASSWORD=${POSTGRES_PASSWORD}
- pgdata:/var/lib/postgresql/data
- backend
webserver:
container_name: webserver
image: caddy:2.4.2-alpine
- APP_DOMAIN=${APP_DOMAIN}
- SERVICE_DOMAIN=${SERVICE_DOMAIN}
- "3000:3000"
- static-content:/var/www/html/app
- caddy_data:/data
- caddy_config:/config
- backend
backend:
static-content:
caddy_data:
caddy_config:
pgdata:
{$SERVICE_DOMAIN} {
{$APP_DOMAIN} {
encode gzip zstd
My question: will restarting the Caddy Docker container dozens of times per day (CI/CD) cause constant renewals for HTTPS certificates?
I have read the documentation Automatic HTTPS — Caddy Documentation as well as the samples on Docker Hub. Currently, I have the front end application building its static content into a shared Docker volume between the app container and the Caddy container. The front end code is being updated all the time. In order to re-attach the latest app volume to the Caddy container I would need to stop the Caddy container, refresh the volume and restart the Caddy container. Does this initiate an certificate renewal each time? I had assumed that it would check the disk (/data or /config) to determine whether a renewal is required but I don’t see this documented anywhere.
Alternatively, is there a better approach to this (fairly common) scenario?
None yet
I am currently using HTTP only in my Caddyfile by specifying :3000 and :80 for the service and web application, respectively
