Caddy configuration is load from JSON file using the curl endpoint.
AWS EC2 (Ubuntu 20.04)
curl localhost:2019/load -H 'Content-Type: application/json' -d @final_with_headers.json
paste full file contents here
use `caddy fmt` to make it readable
or helpers will be sad
Many times, I need to stop-start the EC2 instance. Every time after the restart, the caddy configuration needs to be loaded manually by SSH to the server.
How can I auto-load the configuration file whenever the server is restarted. Just like other proxy providers (apache, nginx), their configuration can be saved inside /etc/nginx/
directory, is there such a way in the Caddy?
Also planning to use auto-scaling to automatically provision new instances on load. Without auto loading, everything a new instance is launched, I need to manually load the configuration.
