Audio Streaming Issues with Caddy Reverse Proxy
I am trying to stream to an Icecast2 Server via a Caddy reverse proxy. For some reason, the stream is interrupted every 10 seconds and the streaming client has to reconnect. I have connected to the Icecast server without the reverse proxy and the drop does not happen, so I believe that the issue is with Caddy. Are there any kind of timeouts that would be causing this?
No errors that I have found. At this time, no error log file has been created.
Version is 2.6.4
Installed Caddy per the official guidelines.
Running the system on Debian 11
No commands being used in the issue.
# domain name.
#:80 {
        #root * /usr/share/caddy
        #file_server
        # php_fastcgi localhost:9000
live.christianradiostreaming.org {
    reverse_proxy localhost:8000 {
        flush_interval -1
old.christianradiostreaming.org {
        reverse_proxy 74.50.119.136:8000
test.stationairtime.com {
        rewrite / /automation/login.php
        reverse_proxy 192.168.135.63:80 {
                header_up host "test.stationairtime.com"
        Cache-Control "no-cache, no-store, must-revalidate"
        Pragma "no-cache"
        Expires 0
www.stationairtime.com {
        Pragma "no-cache"
        Expires 0
None
I can’t say without seeing debug logs. Please follow the instructions in the help topic template, it explains how to get debug logs.
I don’t know how that app works. Is it websockets? Is it an HTTP stream? :man_shrugging:
Did you try without flush_interval -1?
