1. Output of caddy version
v2.6.0 h1:lHDynvM+sTOi9Aq4Y15b4FtkqzPB36WbUrZvVdwzTCA=
docker
docker
caddy docker-proxy --caddyfile-path /etc/caddy/Caddyfile
(auth) {
@check_auth_except {
expression `"{args.0}" == "auth_except"`
not remote_ip forwarded 10.1.1.1/32 10.2.2.2/32
#not working
# not remote_ip forwarded {args.1}
basicauth @check_auth_except {
import /etc/caddy/htpasswd/passwords
(tmpl_except) {
import auth auth_except 10.1.1.1/32
#import auth auth_except "10.1.1.1/32 10.2.2.2/32"
{$MY_HOSTNAME} {
import tmpl_except
It looks like I can’t use args in the remote_ip matcher
If it does work, how could I send multiple IPs in the same arg?
{"level":"error","ts":"2022-09-28T07:34:26.634Z","logger":"docker-proxy","msg":"Error response from server","server":"localhost","status code":400,"body":"{\"error\":\"loading config: loading new config: loading
http app module: provision http: server srv0: setting up route handlers: route 0: loading handler modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 3:
loading matcher modules: module name 'not': provision http.matchers.not: loading matcher sets: module name 'remote_ip': provision http.matchers.remote_ip: invalid IP address: '{args.2}': ParseAddr(\\\"{args.2}\
\\"): unexpected character (at \\\"{args.2}\\\")\"}\n"}
Tried {args.2}, “{args.2}”, `{args.2}`
This works just fine for me:
(auth) {
respond @check_auth_except 403
(tmpl_except) {
:8881 {
import tmpl_except
The config you posted doesn’t match the error you showed. So I don’t understand the issue.
You can’t, because they need to be separate args. But, you can use the new functionality in v2.6.0 to use an expression matcher to do it instead, with pure text instead of Caddyfile tokens:
(auth) {
@check_auth_except `"{args.0}" == "auth_except" && !remote_ip({args.1})`
(tmpl_except) {
import auth auth_except `"10.1.1.1/32", "10.2.2.2/32"`
:8881 {
import tmpl_except
This uses the new shortcut expression matcher syntax, where you can omit expression
if the token immediately following the named matcher is a quoted token.
Obviously this is a bit janky because you need to construct a string that can get inserted into the expression matcher in your import
args, but it should work just fine.
That said, keep in mind that the forwarded
mode of remote_ip
is insecure, be very careful with it. Anyone can spoof this value by setting their X-Forwarded-For
request header to whatever IP address they want.
Thank you, @francislavoie !
I hape no idea where and what I was doing wrong, just getting your example and applying to my setup made it work perfectly.
Moreover, I am also able to use the caddy docker proxy plugin to sent the excepted IP list with the docker labels and it works as well.
In the docker-compose for the container I need to be proxied:
web:
labels:
caddy: subdomain.example.com
caddy.import: tmpl_except_these {{index .Names 0}} password_file `"2.2.2.2/32", "1.1.1.1/32"`
and in caddy config:
(rev_proxy) {
reverse_proxy {
to {args.0}
header_down -Server
(auth) {
@check_auth expression `"{args.0}" == "auth_enabled"`
@check_auth_except `"{args.0}" == "auth_except" && !remote_ip({args.2})`
basicauth @check_auth {
import /etc/caddy/htpasswd/{args.1}*
(tmpl_except_these) {
import rev_proxy {args.0}
import auth auth_except {args.1} {args.2}
Cool, glad it works
You can simplify this one to match, remove expression
there too:
@check_auth `"{args.0}" == "auth_enabled"`
Re forwarded issue, I wonder if there is a way to define the trusted sources for X-Forwarded-For.
Nginx does it through set_real_ip_from .
Not for the remote_ip
matcher, currently. It is possible for the reverse_proxy
though:
system
(system)
Closed
October 28, 2022, 7:46am
8
