latest windows 64 version
as a reverse proxy
windows 10
run
mc.masshate.com {
output file d:\caddy\logs\mc.masshate_access.log {
roll true # Rotate logs, enabled by default
roll_size_mb 5 # Set max size 5 MB
roll_gzip true # Whether to compress rolled files
roll_local_time true # Use localhost time
roll_keep 2 # Keep at most 2 log files
roll_keep_days 7 # Keep log files for 7 days
reverse_proxy 192.168.100.50:80
I can load up the cctv login page (using internet explorer as its the only broswer that the cctv viewer plugin supports), login and it loads the UI as normal then I press play to start the cctv feeds.
nothing happens.
whenever i use the internal address 192.168.100.50 it works fine and displays the feeds
internet explorer has a warning in the console regarding an unexpected token and points to this line
other than that nothing shows up in the log file
sacrifed a chicken to the gods of tech
other than that im not that smart when it comes to this kind of thing I usually just google copy paste and cross my fingers.
