I can’t start up Caddy because of the following error:
Error: loading initial config: loading new config: http app module: start: listening on :80: listen tcp :80: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
I have nothing on port 80. It worked perfectly before, but it just stopped working now and I don’t know why, I haven’t changed anything.
2023/05/30 23:43:25.939 ←[34mINFO←[0m using provided configuration {"config_file": "C:\\Caddyfile", "config_adapter": ""}
2023/05/30 23:43:25.941 ←[33mWARN←[0m Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies {"adapter": "caddyfile", "file": "C:\\Caddyfile", "line": 30}
2023/05/30 23:43:25.957 ←[34mINFO←[0m admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2023/05/30 23:43:25.957 ←[34mINFO←[0m tls.cache.maintenance started background certificate maintenance {"cache": "0xc00051a3f0"}
2023/05/30 23:43:25.957 ←[34mINFO←[0m http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2023/05/30 23:43:25.958 ←[34mINFO←[0m http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2023/05/30 23:43:25.959 ←[34mINFO←[0m http enabling HTTP/3 listener {"addr": ":443"}
2023/05/30 23:43:25.959 ←[34mINFO←[0m http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2023/05/30 23:43:25.960 ←[34mINFO←[0m tls.cache.maintenance stopped background certificate maintenance {"cache": "0xc00051a3f0"}
Download from Caddy website, run with .bat file on startup
Windows 10 22H2 (19045.2965) x64
C:\caddy_windows_amd64_custom.exe run --config C:\Caddyfile
invite.thepwrtank18.me {
reverse_proxy 192.168.1.112:2086
dns cloudflare [censored]
jellyfin.thepwrtank18.me {
reverse_proxy 192.168.1.112:8096
legacy-jellyfin.thepwrtank18.me {
reverse_proxy 192.168.1.112:5678
public.thepwrtank18.me {
header Cache-Control "no-store"
file_server {
root "E:\funny"
