1. Output of caddy version
# docker exec -it caddy caddy version
Caddy running in a docker container (host is Arch)
version: "3"
srv:
external: true
image: caddy:2
- /etc/docker/caddy/data/Caddyfile:/etc/caddy/Caddyfile
- /etc/docker/caddy/data/sites:/data
- /etc/docker/caddy/data/config:/config
- /etc/docker:/etc/docker:ro
- 443:443
- 2015:2015
- ACME_AGREE=true
- LAN_NETWORKS=192.168.10.0/24 192.168.20.0/24 172.18.0.0/16 86.238.84.44/32
- srv
admin 0.0.0.0:2015
email REDACTED
level ERROR
https://syncthing-rpi-dash.swtk.eu {
reverse_proxy rpi-dash.swtk.info:8384
When starting caddy, I see
caddy | Error: adapting config using caddyfile: ambiguous site definition: https://syncthing-rpi-dash.swtk.eu
caddy | {"level":"info","ts":1670849026.009774,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
This is a new error on a previously working version (the last restrat of caddy much have been about 2 weeks ago, so early December 2022). Some minor changes were done in my network, but not around naming or IP ranges.
is the name I would like to use to access rpi-dash.swtk.info:8384
. Caddy runs on a system, rpi-dash.swtk.info
is another one on the same network.
When looking at the code I noticed around caddy/httptype.go at master · caddyserver/caddy · GitHub the following comment which I do not exactly understand (in the referred Issue, @mholt mentions that this is a “particular area of the code”, which does not sound good for my problem :))
What does
// detect ambiguous site definitions: server blocks which // have the same host bound to the same interface (listener // address), otherwise their routes will improperly be added // to the same server (see issue #4635)
mean in the context of my reverse proxy?
