v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=
docker-compose
docker-compose
docker-compose
- CADDY_TLS
- DOMAIN_NAME
- TZ=Europe/London
image: caddy
restart: always
- ./deployment/Caddyfile:/etc/caddy/Caddyfile
- caddy_config:/config
- caddy_data:/data
- django_static:/app/static
- django_media:/app/media
{$DOMAIN_NAME} {
# serve some files directly from caddy rather than through django/unicorn for performance
root * /app # needed for file_server
file_server /static/* # assets e.g. js, css
file_server /media/* # uploaded files e.g. OTA updates
# various reverse proxies which strip the TLS part and pass through http
reverse_proxy /ws rabbitmq:15675 # mqtt websocket for controllers
reverse_proxy /rabbitmq/* rabbitmq:15672 # rabbitmq admin
reverse_proxy /grafana/* grafana:3000 # grafana for internal use
reverse_proxy /portal/* portal:3000 # custom grafana instance for landlord portal
# for all other web requests and not /static or /media, proxy to Django
@not_served {
not path /static/* /media/*
reverse_proxy @not_served web:8000
tls {$CADDY_TLS} # generate ssl cert automatically
encode gzip # encode gzip for performance
level WARN
# don't redirect http->https for firmware as needed by some devices
http://{$DOMAIN_NAME}/media/firmware {
root * /app
file_server /media/firmware/*
By default caddy redirects all http requests to https, but I would like to allow both http and https requests for just one specific path on a website. I tried to do this using the caddyfile above but when I do curl -v <address>
, it shows HTTP/1.1 308 Permanent Redirect
using curl -v
, and is still redirecting to https.
See above
See last part of caddyfile above starting with http:
. I referenced this stack overflow answer but may be getting confused: caddyfile - How to serve both http and https with Caddy? - Stack Overflow
