First line of Caddyfile is the domain.
If someone were to build a hosting service and wanted to allow users to cname their domain to point to the hosting site, there would be no way to know the domain beforehand.
Is caddy capable of handling this scenario and ideally also ask the backend to verify that a domain is allowed?
Thank you very much for reading this question.
Mohammed90
(Mohammed Al Sahaf)
October 3, 2020, 3:53pm
2
Hello, @princemaple ! That’s absolutely possible. The feature you’re looking for is On-Demand TLS . In your Caddyfile, you need to specify the endpoint that will approve or deny the domains using the on_demand_tls
global option . You also need to enable on-demand TLS in the TLS config in the Caddyfile .
matt
(Matt Holt)
October 3, 2020, 4:37pm
3
The first line of the Caddyfile is the site’s address , which isn’t always a domain.
It could be an IP. Or a port. Or a path. Or a scheme. Or any/all of those:
An address always appears at the top of the site block, and is usually the first thing in the Caddyfile.
These are examples of valid addresses:
localhost
example.com
:443
http://example.com
localhost:8080
127.0.0.1
[::1]:2015
example.com/foo/*
*.example.com
http://
So you can specify just a port and Caddy will accept all Host headers for that port.
Thanks a lot! Mohammed and Matt.
I knew about on-demand tls but wasn’t sure if it’d work when it’s not a wildcard subdomain.
Verified locally and it’s working perfectly.
matt
(Matt Holt)
Split this topic
October 14, 2020, 7:10pm
5
system
(system)
Closed
November 2, 2020, 11:23am
6
