1. Output of caddy version
Ubuntu 20.04.5 LTS on a DigitalOcean droplet. Not containerized within the droplet.
caddy reload Caddyfile
I don’t have one.
servers {
metrics
youngren.io www.youngren.io {
root * /var/www/youngren.io
output file /var/log/caddy/youngren.io/access.log
ems.youngren.io {
root * /var/www/ems.youngren.io/build
output file /var/log/caddy/ems.youngren.io/access.log
spacerocks.youngren.io {
root * /var/www/spacerocks.youngren.io
output file /var/log/caddy/spacerocks.youngren.io/access.log
snake.youngren.io {
root * /var/www/snake.youngren.io
output file /var/log/caddy/snake.youngren.io/access.log
fire.youngren.io {
root * /var/www/fire.youngren.io
output file /var/log/caddy/fire.youngren.io/access.log
rpe.youngren.io {
root * /var/www/rpe.youngren.io/dist
output file /var/log/caddy/rpe.youngren.io/access.log
When I look at my metrics in the Prometheus instance running on the same machine, all of the requests counts, save for handler=“subroute” went to 0 around the time I upgraded caddy. I would expect all of the metrics to continue to register after upgrading.
I will note here that I don’t fully understand the implications of the different metrics and have been relying on “file_server” to give me a general idea of the number of http requests as made by a user loading the website in a browser, which is the only thing I care about.
No error messages.
Restarting caddy. I’ve read the caddy documentation on the “subroute” handler as well as the “file_server” handler but it’s not clear why one would keep working when the other stopped.
I should say that the extent of my caddy use is hosting these static sites and the extent of my prometheus use is trying to see how many hits these sites are getting. I know just enough to get it working. Or, I did.
Thank you for your time.
