Hi, I come into a question that how to make access log more detailed? That’s to say if a request is passed to one proxy upstream, I want to show not only common info which I mean ‘time, uri, method, status_code …’ but also proxy info (for example which upstream) in access log. Any suggestions?
Hi there, welcome. You are probably looking for the {upstream}
placeholder that the proxy
directive makes. You can define a custom log format that uses this placeholder to know which proxy upstream the request was sent to.
Oh, that’s true. Thank you for your reply!
