At present, what I hope is to add third-party plug-ins through the source code, but unfortunately I have encountered some problems. Since I am still a super novice, I would like to ask you how to solve it?
As an example to restore the problem, I will show the process of my compilation:
Set the transitional environment variable for Go modules
export GO111MODULE=on
Create a file called caddy.go in the opt/ directory.
touch caddy.go
Edit the caddy.go file,Join the cloudflare plugin
package main
import (
"github.com/caddyserver/caddy/caddy/caddymain"
// plug in plugins here, for example:
// _ "import/path/here"
_ "github.com/caddyserver/dnsproviders/cloudflare"
func main() {
// optional: disable telemetry
// caddymain.EnableTelemetry = false
caddymain.Run()
Then execute “go mod init caddy”
go mod init caddy
Run
go get github.com/caddyserver/caddy
Run
go install
But found the following problem
root@ip:/opt# go install
go: github.com/caddyserver/dnsproviders@v0.3.0 requires
github.com/h2non/gock@v0.0.0-00010101000000-000000000000: unknown revision 000000000000
root@ip:/opt#
what should I do? Can you tell me the solution? I am still a newbie
matt
(Matt Holt)
August 3, 2019, 2:33pm
#2
What is your go.mod?
Try removing $GOPATH/pkg/mod and also try go get github.com/caddyserver/dnsproviders@c2e7db47dc629b8813286b70ff106a4fc55bfb3b
(the latest commit, instead of latest release).
I tried to delete $ GOPATH / pkg / mod and try go get github.com/caddyserver/dnsproviders@c2e7db47dc629b8813286b70ff106a4fc55bfb3b , but the following problem still occurs:
root@ip-172-31-32-102:~# go install
go: downloading gopkg.in/natefinch/lumberjack.v2 v2.0.0
go: downloading github.com/jimstudt/http-authentication v0.0.0-20140401203705-3eca13d6893a
go: downloading github.com/gorilla/websocket v1.4.0
go: downloading github.com/dustin/go-humanize v1.0.0
go: downloading gopkg.in/yaml.v2 v2.2.2
go: downloading github.com/hashicorp/go-syslog v1.0.0
go: downloading github.com/russross/blackfriday v0.0.0-20170610170232-067529f716f4
go: downloading github.com/lucas-clemente/quic-go v0.10.2
go: downloading github.com/naoina/toml v0.1.1
go: extracting github.com/hashicorp/go-syslog v1.0.0
go: extracting github.com/naoina/toml v0.1.1
go: extracting gopkg.in/natefinch/lumberjack.v2 v2.0.0
go: downloading github.com/naoina/go-stringutil v0.1.0
go: extracting github.com/russross/blackfriday v0.0.0-20170610170232-067529f716f4
go: extracting github.com/naoina/go-stringutil v0.1.0
go: extracting gopkg.in/yaml.v2 v2.2.2
go: extracting github.com/dustin/go-humanize v1.0.0
go: extracting github.com/gorilla/websocket v1.4.0
go: extracting github.com/jimstudt/http-authentication v0.0.0-20140401203705-3eca13d6893a
go: extracting github.com/lucas-clemente/quic-go v0.10.2
go: downloading github.com/bifurcation/mint v0.0.0-20180715133206-93c51c6ce115
go: downloading github.com/cheekybits/genny v0.0.0-20170328200008-9127e812e1e9
go: downloading github.com/lucas-clemente/aes12 v0.0.0-20171027163421-cd47fb39b79f
go: downloading github.com/hashicorp/golang-lru v0.0.0-20180201235237-0fb14efe8c47
go: downloading github.com/lucas-clemente/quic-go-certificates v0.0.0-20160823095156-d2f86524cced
go: finding github.com/caddyserver/dnsproviders v0.3.0
go: extracting github.com/bifurcation/mint v0.0.0-20180715133206-93c51c6ce115
go: extracting github.com/lucas-clemente/aes12 v0.0.0-20171027163421-cd47fb39b79f
go: extracting github.com/hashicorp/golang-lru v0.0.0-20180201235237-0fb14efe8c47
go: downloading github.com/caddyserver/dnsproviders v0.3.0
go: extracting github.com/cheekybits/genny v0.0.0-20170328200008-9127e812e1e9
go: extracting github.com/lucas-clemente/quic-go-certificates v0.0.0-20160823095156-d2f86524cced
go: extracting github.com/caddyserver/dnsproviders v0.3.0
root@ip:~# go get github.com/caddyserver/dnsproviders@c2e7db47dc629b8813286b70ff106a4fc55bfb3b
go: finding github.com/caddyserver/dnsproviders c2e7db47dc629b8813286b70ff106a4fc55bfb3b
go get: github.com/caddyserver/dnsproviders@v0.3.1-0.20190725163104-c2e7db47dc62 requires
Still not, suggesting an error
matt
(Matt Holt)
August 3, 2019, 4:42pm
#6
OK, the problem is solved
system
(system)
closed
November 1, 2019, 4:59pm
#8
