1. Caddy version:
Downloaded from caddy website with transform-encoder and vultr. I run caddy via the systemd unit provided with the debian package.
Linux 5.10.0-21-amd64 #1 SMP Debian 5.10.162-1 (2023-01-21) x86_64 GNU/Linux, systemd
Paste command here.
# caddy.service
# for your installation.
# domain name.
(_unauthorized) {
error {args.0} "Unauthorized" 403
*.xinayder.me xinayder.me {
# disable FLoC tracking
Permissions-Policy interest-cohort=()
# enable HSTS
# clickjacking protection
X-Frame-Options DENY
Referrer-Policy no-referrer
output file /var/log/caddy/xinayder.me/access.log {
roll_size 10MiB
format transform `{request>remote_ip} - {request>user_id} [{ts}] "{request>method} {request>uri} {request>proto}" {status} {size} "{request>headers>Referer>[0]}" "{request>headers>User-Agent>[0]}"` {
time_format "02/Jan/2006:15:04:05 -0700"
tls cert@xinayder.me {
dns vultr <REDACTED>
resolvers 9.9.9.9
@matrix host matrix.xinayder.me
handle @matrix {
reverse_proxy /_matrix/* http://localhost:8008
root * /var/www/xinayder.me
file_server {
hide blog tags categories
# import _unauthorized /blog/
# import _unauthorized /tags/
# import _unauthorized /categories/
# error blog "Unauthorized" 403
# error /blog/index.html "Unauthorized" 403
handle_errors {
rewrite * /error.html
templates
@resume {
header User-Agent *curl*
path /
rewrite @resume /resume.json
# handle_errors {
# @403 {
# expression {http.error.status_code} == 403
# redir @403 /403.html
# @404 {
# expression {http.error.status_code} == 404
# redir @404 /404.html
# @500 {
# expression {http.error.status_code} == 500
# redir @500 /500.html
# php_fastcgi localhost:9000
@irc host irc.xinayder.me
handle @irc {
reverse_proxy localhost:9000
@znc host znc.xinayder.me
handle @znc {
reverse_proxy localhost:1030
@hass host hass.xinayder.me
handle @hass {
reverse_proxy edupenna.duckdns.org:9999
header -X-Frame-Options
@websockets {
header Connection *Upgrade*
header Upgrade websocket
@ntfy host notify.xinayder.me
handle @ntfy {
reverse_proxy localhost:9005
# Redirect HTTP to HTTPS, but only for GET topic addresses, since we want
# it to work with curl without the annoying https:// prefix
@httpget {
protocol http
method GET
path_regexp ^/([-_a-z0-9]{0,64}$|docs/|static/)
redir @httpget https://{host}{uri}
header /.well-known/matrix/* Content-Type application/json
header /.well-known/matrix/* Access-Control-Allow-Origin *
respond /.well-known/matrix/server `{"m.server": "matrix.xinayder.me:443"}`
respond /.well-known/matrix/client `{"m.homeserver": {"base_url": "https://matrix.xinayder.me:443"}}`
As seen on my Caddyfile, I have a single block handling my wildcard and root domain and it also handles my reverse proxy subdomains. The problem with this approach, however, is that any request to an unhandled subdomain will be redirected to the root site, which I believe is the result of root
and file_server
directives.
I was worried that separating these two would cause Caddy to issue separate certificates for the wildcard domains and the root domain, but that already seems to be the case? I checked the certificate for my website and it doesn’t list the wildcard subdomain on the CN field.
With this in mind, if I separate the subdomains from the root server block, I would need to copy the TLS directive as well as any other directives I’d like to be common directives for these two configurations, right? For example, if I want to include the header
directives, should I create a snippet and import it in both domain blocks? Do I also need to copy the log
directive to the subdomain block?
Also, what I wanted to achieve was: any request to an invalid path will return a 404; this counts subdomains as well, if I access a subdomain that isn’t handled by caddy, it should return an error or just abort the request. Right now even if I access a subdomain like testxsd.xinayder.me, it will redirect me to my main page, which isn’t what I expect.
N/A
