I’m trying to download Caddy using curl https://getcaddy.com | bash -s personal as I always did, but this time I got Downloading Caddy for linux/amd64 (personal license)... Aborted, download verification failed.
It’s running on a Amazon EC2 Tokyo instance, purely new installed Amazon Linux 2 AMI.
I’ve googled but found nothing helpful. What is wrong?
Hi @matt, that’s basically all the output. More here:
[ec2-user@ip-x-x-x-x ~]$ sudo curl https://getcaddy.com | bash -s personal
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 7380 100 7380 0 0 13692 0 --:--:-- --:--:-- --:--:-- 13666
I also had commanded it as directly root user, it produced the same result.
Still running into the issue? Worked fine for me just now.
whitestrake at ishtar in ~
→ curl https://getcaddy.com | bash -s personal
100 7380 100 7380 0 0 7409 0 --:--:-- --:--:-- --:--:-- 7402
Download verification OK
Extracting...
Backing up /usr/local/bin/caddy to /usr/local/bin/caddy_old
(Password may be required.)
[sudo] password for whitestrake:
Putting caddy in /usr/local/bin (may require password)
Caddy v1.0.0-beta2 (h1:sG4ac7b3dlTdJG2Jb1q0NxFPDGz6kKA+VXM3QSgvhII=)
Successfully installed
